Captmandel
Hi everyone! Its been a while, but I am back at it.
So heres the case, i have an xs2 with pamco, pma, kick only, with sparx cap.
Bike starts up on first or second kick. with headlight off, the tail light is off. With headlight on high beam, tail light is on, but the headlight is dark. With head light on normal beam the engine dies. If I rev the engine up when I switch to normal beam, the headlight comes on but the tail light turns off. With the head light on the brake switch kills the power.
I also tried turning the idle up, to get more power going and it didnt seem to work. In fact all it did was make gas leak out of a barb on the bottom of the right carb.
I think the head lamp should be replaced. I am thinking maybe I have a bad ground? Or maybe the pma isnt making enough power for everything? Bigger cap? Better stator?
I bought a bunch of wire to make a simplified wiring harness but I would love to just get everything going first before I rip it apart.
The tail light is a TC Bros. Black 33 Ford Replica Side Mount Tail Light/License Plate Bracket. but that seems to be working fine.
Let me know if I left out any vital info. Any advice, help, or tips are appreciated. Thanks in advanced!
