It's not possible to ground it, really. The two mounting screw holes don't connect to anything in the coil.
To test the pickup, read 700 ohms from the black to each of the other two. Lookingfor continuity might work too, don't know, if you don't have a meter. Look at the diagram at the top of this thread to tell you if you should be seeing 12, ground, or don't know for every wire out of the tci. If you don't see it, check continuity. And check continuity from the tci to the pickup. That should get you going. Probably nothing's broken.
