pa23driver
So i recently cleaned the carbs and put the correct jets in my 1977 BS 38's. The sizes i chose were 27.5 on the pilots and 132 on the mains. so i tried starting it, it would run for a couple seconds then quit and would not accept throttle. after a nasty back fire (blew the carb out of the boots) i decided i better check the timing (points). so i reset the point gaps after putting in new adjustment screws, and re-timed the ignition. so i try restarting it and got nothing. so i proceeded to pull the plugs and found that they were completely fuel fouled, so i bought new spark plugs and installed them, and for the hell of it tried running the bike again - nothing. so i figured it was a low battery caused by tinkering with ignition switch on too long (had no spark on new plugs), set the charger and went to bed.
messed with the bike again today, checked to see if there was spark (there was) and tried restarting the bike - nothing. rechecked the timing (dead on) and decided maybe i'm just too rich, pulled the float bowls and put in size 25 pilot jets (stock size). tried restarting and nothing, not even a rumble. pulled the plugs and they looked brand new, not a spot of carbon on them, but i could smell fuel. sprayed some starting fluid into the carbs, kicked about 20 times, got her rumbling for a few seconds until she died. pulled the plugs and they looked brand new with no carbon at all on them. decided maybe i should check valve clearences - they're within spec. and throughout this i was playing with the idle mixture going between 1/2 turn to 2 1/2 turns with no luck.
so my question is any ideas as to what is going on with this thing?
is it possible i'm really that bad at timing the ignition (static timing with a test light)?
or is it possible that the bad backfire could've done something to my carbs or engine?
any input is much appreciated
