Brayden2980
XS650 New Member
Hello, I lost the key to my bike and installed a new one, everything was working fine including lights, ignition, and horn. I recently redid the carbs and put on aftermarket intakes, after installing the tank back on and plumbing everything, nothing comes on at all. When turning key, nothing happens and no lights come on either. I checked for loose connections everywhere and couldn’t find one and the battery is on the maintainer and should be good. I checked the diy connections of the new ignition and all was good still. Any suggestions? I checked the oem air box and there’s no electrical connections or sensors, and I plugged the connection from the tank in as well.
With the new intakes, I was also wondering what to do with the vacuum lines.
I’m definitely a novice with electrical work so could have easily overlooked something. Please let me know even the most basic solution.
