When I rebuilt my 75 engine, as a 2nd over 650, on the engine stand, all parts generously covered with engine oil on assembly. No carbs and cranking with the e-start, I got 165 PSI compression.
After I installed Mike's 750 kit, on stand, well oiled, e-start I got 195 PSI compression.
Your engine may be slightly different than mine but with a increase from about 8.1 to 1 compression ratio to about 9.5 to 1, the PSI will increase. The 8.1 to 9.5 is about a 17 % increase. That should give about the same increase in PSI. My 165 + 17% = 193. That's what I got. If I did another 750 kit I would expect at least 175 PSI compression.
When you did the 750 kit, did you do a valve job, Lapping the valves and seats and install new valve seals?
