strungxout
Awesome
Ok, so I guess my bike learned a couple magic tricks over the weekend. Cleaning the points fixed my weak spark issue, now on to more problems. So when the bike is running it idles fine, throttle response seems ok. But when you turn the wheel to the right, and only the right, the engine revs up. If you watch the throttle level on the carb, you can see slack in the throttle cable through out the rev... the farther right you turn the wheel the higher the rev. And I'm not talking it just upping the idle a little bit, if you cut the wheel right and leave it there the damn thing will redline all day. It has nothing to do with the throttle, if you disconnect the cable you'll get the same results. The only other thing I could think of is maybe somehow its advancing the timing? But I don't see how that's possible just by turning the wheel? No wires or cables are pinched, fuel is flowing the same, its just like its posessed or something. Has anybody ever heard of this, or have any idea what it could be? Because the only thing I can do for it now is to have an exorcism...
