Motor is probably fine. Takes more then that to hurt an XS. Don't be over concerned about the comp test numbers, as long as they are even and not real low, under 100. Your crank speed, throttle position and gage itself will vary the outcome. I too found similar issues with a few bikes. Carb sync is one of those first things to set once running, after with timing, valve clearance and cam chain is all done. Get a set of vacuum gages or build your own manometer. I find the gages to work fine, spend a few $ and save time. Or go the other way if that is your situation.
