Hairyblackdude
I recently ordered a set of really expensive custom brake lines..
They work & look awesome, However- When I measured for them, I failed the notice that the forks were not in the correct position. They are too short for me now.
I figure someone will have a use for these.. I would hate them to go to waste.
They are slightly too short for a stock setup, unless you mounted the brake manifold LOWER or lowered your forks..
It is UP TO YOU to decide if they will work for you.
They are custom Galfer Brand braided brake lines. They have a "smoked" color covering.
They are 19" long from center to center of the fittings.
1 brake line has a straight fitting & a 40 degree fitting.
1 brake line has a 20 degree fitting & a 40 degree fitting.
The ends swivel with use of pliers, so you can turn them however you need..
I paid almost $150 for 3 lines.. Im only asking $60 for BOTH of these lines.
They were installed with fluid on the bike for 4 days. Never saw outside & are practically brand new.
Thanks.
_marc
Thanks.
_marc
