Question about a bolt size
Eric12171
Pennsylvania
Hi again,
I managed to lose the bolt that holds the tach drive into the case .
Is there any chance anyone has one handy and could put up some measurements ?
I’d rather make one than pay $5 each and $16 in shipping.
Thank you .
Here you go.
You could probably chuck the head of a 15mm m6 bolt in a drill and reduce the end diameter on a bench grinder, done.
Old DIY trick; run a nut on the bolt then you can tighten both the bolt head and nut in the drill chuck for better stability as you grind.
