MUCH less, than the risk of leaks if you DON'T tighten them. IM(maybe not so)HO.
Think about this a little, is it a good idea to have ONE tight bolt and seven loose ones? While doing a retorque the other day ( I re-torque every XS650 that goes on the lift before I even see if it will run) as an experiment I checked how much torque it took to LOOSEN the nuts, well over 50 pounds to crack loose and free the nut from the stud. Don't forget the two bolts under the plugs. 12mm short 3/8 socket and a breaker bar it's a snug fit getting on those two. and the 10mm head small little bolt above the cam chain tensioner, careful not too much torque on that one.
