Yamadogrick
Hi guys, getting ready to reinstall my engine into my 77 frame. Removed it using the tried and true method of removing most mounts/bolts and tipping frame over onto blankets to slide the motor out. Any tricks you all use to reinstall the motor? I'm thinking reverse the process, fitting the bottom bolts first (backwards?) when lined up and then one more upper set of bolts and raise her upright from there. Any tricks you've found to ease the process most welcome! TIA Rick, in Florida
