Hello,
I have a '75 XS650B, about to do a top-end rebuild. I've removed the points on the left side, remove the rod, and have removed the advance weights/springs on the right side.
But I'm stuck on removing the advance unit plate. It seems to be attached by a cogged advance retainer nut. The retainer nut won't budge from the plate at all. I looked up some info, and I *think* the way to do it is to use a screwdriver and hammer to turn the nut:
The problem is, each time I whack the hammer, the blows seem to be absorbed because the retainer nut moves along with the advancer plate as a single unit -- and that moves the cam itself and all its innards (the cam chain and everything else it's connected to inside).
With each whack, I can literally hear everything mechanically moving inside, and feel it all "bounce" back, but the retainer nut won't move independently of the advancer plate.
I've stopped because I don't know if continued blows will do any damage inside the engine. Am I doing something wrong, or is there a better way?
Thanks
Thanks
