A little pratice on the kick start procedure will help too. With the key off slowly kick it over to find TDC. It gets harder to turn as it reaches TDC.
Now with it on TDC set the choke, turn on the key and give it a good solid kick through. You don't have to jump on it with all your wieght, just a good solid kick and don't stop half way through. Go all the way to the bottom of the stroke.
Repeat as nessesary. Depending on your bike slight variations on the procedure may help. Like with the key off choke on kick through twice then with the key on.
Maybe hold the throttle open slightly.
As in most things about this bike is no two are just alike.
Thats part of the fun. A good heavy work boot with plenty of ankle support helps, use the ball of your foot not the instep helps.
Once you get it running set your timing with a light. set it so the rotor mark is more toward the right side of the F marks. Thats slightly retarded from center of the F marks. I think the two F marks are about 3 degrees apart. So from center you get about 1.5 degrees each way.
Once you get it set at idle check the full advance It should move over to but never past the full mark.
On mine I have the Pamco and a new ATU from Mike's. I think the advance is just a hair wide. At idle I'm just a hair right of the right side F mark, and at full advance I'm just to the left of the full mark. Not much either way. the marks just touch the outside of the marks. \so at idle I'm timed to 12.5 or 12.75 instead of 13. and on the full side i'm maybe 38.25 or 38.5 instead of the 38. Not enough to worry me. I can always use Grizld1's peen the tips fix.
My carbs are my tuning issue right now. I replaced my BS38's with a pair of BS34's.I have upped the mains one size. I have ridden it a about 150 miles getting a feel for them. I need to bump the mains one more maybe two, the pilots up one and try it.
Anyway sorry about the foot. Glad it's just a sprain, not broke.
Do you still have the starter? It might be a good idea to use it till you get it better tuned.
Hearing roar to life that first time is an amazing feeling. If your like me even after a few years when I start the 75. I get a thrill, thinking I did this.
