hi people. I'm rebuilding my engine and commonly come across the need to blow through parts / dry / clean things ideally with compressed air. I don't have a compressor and only a small garage and wondered what I could use for such tasks. Can anyone recommend a small compressor for such tasks? I wondered if the little ones used for airbrush stuff would be good enough? So something like that. A full size compressor would seem to be overkill. Any thoughts? I'm in the UK by the way. Cheers
Hi adi,
at least in the UK there's 240V power not the pathetic North American 110V stuff than means having to get a 220V line installed in the garage to run more than a fractional horsepower motor.
Tell you what NOT to get, an oil-free direct drive compressor. Yes, they cost less but they are massively noisy and are quick to self-destruct.
Get an old fashioned compressor that is belt driven and needs oil for lubrication.
Never mind the tank size, either. What's important is the CFM number.
6CFM minimum, 10CFM is good.
With 10CFM you can do anything short of serious grit-blasting.
In a small garage, save space by getting a compressor that has it's tank standing upright with the motor & compressor on top.
WARNING
Air tools are addictive. It starts with a blower nozzle, then a paint gun (+ pressure reducer + dryer + filter) ; next an impact wrench and perhaps a nut-runner. Then it gets worse. You have been warned.
