Holy cow folks - a fella takes a long ride one day and comes back to find everyone barking at each other and calling each other names.
I am an automotive engineer and while I haven't studied everything that has been said in this thread, I have seen a few clangers and a couple of missed points which I will comment upon (without attribution and
YES I know that I am paraphrasing here - so handle it):
- "rear brakes are totally useless" - WRONG. As long as there is weight on a wheel, having a brake on it means that it can contribute both to slowing the vehicle and to helping maintain directional control;
- "drum brakes fade and discs do not and that is why drums aren't used anymore" - WRONG - all mechanical brakes can fade - drum, or disc - and drums are still used in certain applications by reputable companies on modern vehicle designs.
The reason why
modern brakes (of either kind) do not fade as much as
older brakes is due to better metallurgy, more sophisticated hydraulic systems, better hydraulic fluids and better friction materials. BELIEVE me - older disc brakes were crummy too.
Many folks may know this - but what the hell, I am going to say it anyway....the thing to understand about brake fade is that it is really a matter of heat rejection
rate.
A brake is a device for converting kinetic energy (
the energy of motion) into heat and their good operation depends on being able to get rid of that heat quickly (i.e. at the highest
rate). Most drum brakes have more thermal mass than most discs - and so they while they may heat up more slowly than a disc, they also cool down more slowly and so drum brakes often have difficulty rejecting the heat as quickly. However, there were drum designs that worked really well and there were discs that did not. It just isn't quite that simple.
The other issues about drums and discs are not related directly to braking performance. Disc systems are generally lighter, have few parts and are easier to service than comparable drums - and
THOSE are also key reasons why they have largely replaced drum brakes.
LIGHTER: Reducing the mass (i.e. weight) of the parts of a vehicle which are attached directly to the wheel assembly and which are "downstream" of the suspension, is called reducing the "unsprung mass" of the vehicle. I won't go into the math, but in terms of vehicle handling and ride, you want
less unsprung mass and not more. Another strike in favour of discs - but not directly related to braking performance.
PARTS COUNT: The auto industry constantly strives to reduce the parts count of every on-board system to reduce overall weight and reduce cost. Disc brakes win again - but not because they're better brakes - because they are
cheaper.
SERVICEABILITY: car companies care about serviceability (obviously, some more than others....), and there is no question that disc systems are much easier to service than drum systems.
About the above, I sure am not the world's leading expert on brakes, but I do know some folks who are - and that is what they tell me.
Pete
