Sprocket torque specs
RG,
Thank you very much....wrench in hand:thumbsup:
roy
I was looking at my Haynes manual for torque specs and if there in there I couldn't find them either
(1975 xs) should be the same
Just put the new rear sprocket on at 30lbs so it should be fine ? Front will go to 80lbs
Thanks
From the '78 650E factory manual, one of the few I've found that lists this .....
full
The front sprocket nut is one of those torque values that Yamaha changed numerous times, and for no apparent reason that I can see. Those parts it applies to didn't change. It was as low as 36 ft/lbs on some of the later models while the early models speced it as high as 94 ft/lbs. The most common spec you'll find is 72-87 ft/lbs, so 80 should be fine. But, you could go even tighter. Most of us agree that making this nut REALLY tight is the best way to insure no oil leaks from the sprocket shaft seal.
I will take the front sprocket torque to 90- 94lbs
I was just concerned that I over torqued the rear being as I'm torqueing steel into aluminum
What I need is 2 650's one to work on and not be afraid to do more repairs on and 1 to ride then I won't have to be so cautious about wrenching I'm on the lookout for a 74 it's out there
Thanks 5twins !!!! without you guys the Yamaha dealer would definitely be making more money off me
I also need a factory manual !! the Haynes manual assumes you know what you should be doing
"install wheel in reverse order " no tourque specs etc. and the pictures suck
There are steel inserts into the aluminum hub where the sprocket mounts to, so really no need to worry about stripping the aluminum. But, the sprocket mount holes open into the brake drum. They are exposed to all sorts of dirt, brake dust and possibly water. Liberally anti-seize the sprocket mounting bolts or they can seize up big time into the hub. I've encountered several like that, some so bad that the heads were broken off the bolts. The bolts are a fine thread so when they seize up, they do so very badly.
Yes, most of us agree the factory manual is best. You can download free copies of most of them from the XS Cafe. It helps to have more than just the one that covers your year. This sprocket bolt torque is the perfect example. I don't think you'll find it listed in the '75 manual. Many of us prefer to have a paper copy, the actual book. It's much easier to use when working on the bike instead of having to run and look at your computer all the time.
Watch eBay, used, reasonably priced copies pop up all the time. Yamaha didn't publish a full manual for every year, full manuals only came out every 3 or 4 years. The in between years got small 10 to 15 page supplements covering any differences in that model year. They were made to be used along with the previous last full manual. For your '75 model, you'll want to look for the '74-'77 full manual .....
full
I also suggest getting the '78 full manual and if possible, a version that includes the supplements up to '80 or '81. That will cover all the bases including the change in '80 to electronic ignition and BS34 carbs. Obviously, you don't need that info now, but you never know what the future may bring. An '80s model so cheap you can't pass it up may fall into your lap some day.
full
full
full
I'm looking too see what kinda 650's are out there I found my 75 in White SD via Craigslist few hrs drive but worth it
Thanks again!!!
Here's a 78E manual. I don't have anything older....
  • XS650 shop manual.pdf
There is a link to the 75B manual in post #5. https://www.xs650.com/threads/xs650...workshop-manuals-and-other-information.30569/ This takes you to the Dutch Xs650 site and you need to scroll back up a couple of inches for the B manual. This is a very good manual in 3 languages easy to work out..
Full 75B service manual in JPEG file HERE from Post #6............Torque settings from the 75B manual one of the JPEG files i posted.
https://www.xs650.com/attachments/chapter-7-appendixes-03-jpg.36287/ from post #29
or download the 75B service manual PDF file from https://thexscafedotcom.wordpress.com/tag/xs650b/ and all XS650 Manuals, Parts and Handbooks........https://thexscafedotcom.wordpress.com/tag/manual/
WoW thanks It's time to do a little printing and reading
