YL82
Perpetual Restorationist
Just about had my BS38 CV Carbs re-assembled and BAM! wouldn't you know it, I stripped out the little hole where the Carb Choke Lever (i.e., Starter Lever) fastens to the carb body.
After I initially stripped out the female threads (which aren't that far up into hole due to short screw), I went with a SST M4 x .70 Pitch x 13 mm socket head screw I had left over from my float bowl screws. This likely finished off what was left of the female threads further up into the cavity.
I've never done a helicoil thing before. Is this the way to go? If so, what do I need and where do I get it and how do I do it?
NEED HELP!
Thanks!
NEED HELP!
Thanks!
