voelser
While stripping the bike I discovered that somebody along the line had already replaced the stock bearings by tapered steering bearings. Good news as it saves me some money. However as I would like to have the lower yoke freshly powdercoated and the lower dust seal is torn I would like to remove the lower bearing. But I'm not sure you can (or should). I have really tried yet as I don't want to do any damage, but it seems pretty solid. So, can it be removed (I think the answer is yes), to be re-used and if so, what's the best way to do it?
Incidentally I have the same issue with the bearing cups in the frame: they are solidly in there, but I guess it is less of an issue to leave them in as in the inside won't be powdercoated anyway.
Thanks!
Thanks!
