want to put and old school Triumph tank on my 79 XS650
Jae-
Got a couple pics today of my tank mounts. The first shows where I welded on a flat bar just under my coils. I used modified rubber stoppers with some holes drilled through for mounts to quell the vibes.
Second pic shows the bracket at the back. You can also see how I closed the back of the tunnel on the tank. This did two things, first, since my tank sits higher is closed off the nasty gap and second, it let me put a flat mounting point underneath the tank that mates up with my bracket.
You will likely need lock washers to keep things from shaking loose.
