XStretchified650
Back in the 650 Saddle
I have been putting on the break-in miles on a complete restoration and I have a frustrating issue with the cam chain adjuster cover. I am looking for a helpful hint on how to snug down the adjuster cover without it making further adjustments to the cam chain tension.
The 77 adjuster does not have a locknut. I can set the tension for the correct plunger position just fine. But when I install the cover and am getting it close to full seating it rotates the tensioner bolt and I lose the proper setting. The cam chain gets over tightened, I can't see it but I know the bolt has rotated plenty.
I use a torque wrench but the bolt begins to rotate when I am still just able to turn it with my fingers. The cover does not leak. The O-ring looks fine and it protrudes nicely from the seat, I'll try a new one anyway. Has anybody solved this with a new O-ring?
I have had the bike for decades and in it's prior life I did not have this problem.
Did I tell you there is no locknut?
...XStretchified
...XStretchified
