I haven't talked to factory engineers....
When Yamaha stopped using the advance rod, 80 on they quit final reaming the cam bore to accept the bushings. Try driving a bushing in a too small hole and something has to give, the thin neck at the back of the threaded area is often the loser. Another possibility is sloppy tolerance, (too big OD) of aftermarket bushings. Result would be the same.
