650cafexs
- Messages
- 12
- Reaction score
- 0
- Points
- 1
Hiya folks, I'm new to the forums, and motorcycles in general (picked up my first bike, a 78 XS650 SE a week ago.) The bike ran fine without much problems getting it home from the seller, a little sluggish, but I figured it was from the bike sitting for a few years. I came out to the garage later the night I got it home, and found a puddle of fuel under the left hand side of the bike, my side cover paint blistered, and my frame paint running away - I'd shut the petcock on the left hand side off, but didn't realize there was one on the right-hand side for at least another day, after replacing shop towels in the air cleaner port to soak up the seemingly endless flow of gas.
Once I figured that business out, the bike ran decent for awhile, then seemed like the right cylinder was unhappy. Not really knowing anything about bikes and being pretty green when it comes to engine work (22 years old, first automotive project) I decided to tackle the cam chain / valve / timing to see if that would solve anything. I followed a guide for the cam chain, took a quick look at the pin, everything seemed normal. Adjusted the valves to where the guide said they should be (.004" on the intake end , .006" for the exhaust.) Followed the instructions, buttoned the valves back up, took a look at the timing, everything seemed to check out there, so I closed her back up and let her idle, everything seemed fine except for it was still idling around 2,500.
Aside from the idle, the bike seemed happier, no obscene noises or popping from the right hand side - I figured maybe I fixed it, or it just finally settled - took it for a couple 5 mile rides around the neighborhood, everything seemed better, aside from my neutral light mysteriously flickering and eventually dying (Didn't bother me, too much) - parked it, and got ambitious...
My girlfriend was with me and told me her brother adjusted the idle on their dirt bike all the time, and that she could show me how to lower mine - so I jumped on the idea without reading up on it after being careful and spending forever doing my first valve / cam chain maintenance dealie, and grabbed a screwdriver
. We had a pretty good idea which screw it was, and she decided against what I now know to be the RIGHT screw - but I trusted her, and turned what looks like the idle mixture screw. The idle seemed to lurch for a second, and I was relieved, then it picked back up and that's when I knew we turned the wrong one. I tried to get the screw back to where I thought it was, then proceeded to turn the correct screw, and dropped the idle down to about 1,200 - 1,500.
After the bike idled for a few minutes, the right exhaust got noticably "poppier" and white, gassy smelling smoke starting coming out of the right exhaust - and now it does this whenever I start the bike and let it idle for a couple minutes. I'm just curious if it has something to do with me screwing the valves up? (Don't think so since it right nicely up until the carb incident) Or if turning the idle mixture screw on the left hand side of the carb could cause the white smoke from the right hand side. Sorry for the novella posting, just figured I'd try to be as thorough as possible
.Once I figured that business out, the bike ran decent for awhile, then seemed like the right cylinder was unhappy. Not really knowing anything about bikes and being pretty green when it comes to engine work (22 years old, first automotive project) I decided to tackle the cam chain / valve / timing to see if that would solve anything. I followed a guide for the cam chain, took a quick look at the pin, everything seemed normal. Adjusted the valves to where the guide said they should be (.004" on the intake end , .006" for the exhaust.) Followed the instructions, buttoned the valves back up, took a look at the timing, everything seemed to check out there, so I closed her back up and let her idle, everything seemed fine except for it was still idling around 2,500.
