I bought new fork seals for my 34mm front end, but the old ones are such a %$tch to get out, I was wondering just how necessary it is to change them. If they are in there so tight, they must still be sealing the forks just fine. (?)
The current forks I have weren't leaking, they were just sitting in a barn for 15 years so I figured for a few bucks I might as well put in new seals. The dust boots, washer and clip were not in very good condition and will also need to be replaced. I found a nicer set of forks this weekend that I will likely use instead, but it is the same situation - I have new seals on hand, but the old ones are such a pain to remove, is it worth it to put in new seals just for the sake of being "new"?
