mrriggs
XS650 Junkie
The reason for regulators to be set around 14.5 volts is so that a lead-acid battery will receive a constant charge and not be overcharged. Since you do not have a battery, you don't have to worry about that.
The lights are made to run around that voltage since that is what the regulator has to put out for a battery. Lights are rugged and will run on a wide range of voltage. If you haven't already blown them out then you are probably fine.
Ignitions run off of current. Voltage doesn't matter unless the ignition has a fixed duty cycle and resistance. I assume the Boyer has a current regulator and variable duty cycle so an extra volt shouldn't phase it.
I'd say the 15.4 volts is not the cause of your troubles but it may be an indication of the true cause. Have you tried hooking up a battery again to see if that cures the running issues?
I suspect the regulator is oscillating which could explain the high speed miss and erratic voltage at lower speed. A digital volt meter won't tell you much about how the regulator is working when you don't have a big old lead-acid battery to smooth everything out. In that case, you really need to check it with an oscilloscope.
