ANLAF
XS650 Guru
Fellers
My voltmeter arrived all the way from China. Recommended by reviewers on eBay, so who am I to doubt - well, yes, I do doubt, so I got two of the things to double check.
The bike has been running very poorly, progessively worse. Thought it was the carbs. TwoMany said 'Might be the ignition'. I wired in the volmeter and found loose connections at where the two cable from the Boyer ignition link to the wires coming out of the digital box. Started up - but WOW! the voltmeter was reading 15.1v. THen between 14.7-15.1v.
Oh! dear - this isn't what I expected.
I swapped the voltmeter for the second voltmeter that arrived from different supplier, and reading just the same high-up 15.1v.
I'm running a HUGH's PMA and rectifier that he sent last summer.
Battery died on me last month (hmmm! this why?) and on capacitor now. Isn't the regulator supposed to regulate that to c.14.4v? Bike running fine on 575 miles around Wales three weeks ago apart from spluttering over 50 mph. Changed HT leads, seemed to cure it, but progressively worse from then. First, I'm worrried I am damaging stuff (I've downed tools in case the electronic ignition gets it) Second, I want to know what the problem is! Third, I want to fix it.
Any help gratefully received fellers.
