mrriggs
XS650 Junkie
On that trace, with a battery in the system, it doesn't. But replace that battery with a cap, and slower kickstart speed, those bumps become RC sawtooth. The draw of a coil in dwell could drain the cap (depending on cap size/type) to voltage levels much lower than the battery supplied drop (pictured above), especially since kickstarting usually begins when the rider senses the start of the compression stroke, when the coil would normally be conducting (or just about to).
That may be true with a single-phase alternator but on a three-phase alternator the cycles overlap so voltage never drops to zero.
I don't have any voltage traces of my bike at kicking speed but I do have one showing primary current in the ignition coil at kicking speed. Since the ignition only cares about current and your concern is that the ignition is not getting what it wants, then I think it's relevant to the discussion.
As you can see, the alternator has no trouble bringing the coil up to full current and holding it there until it fires (pink line).
I'm running a little 3000uf capacitor in place of the battery that can only hold about 200 millijoules of energy. The coil is consuming over 300 millijoules per revolution and I do not turn off the headlight or tail lights when starting. I haven't measured the headlight draw at kicking speed but I would guesstimate at least 4000 millijoules per revolution. So it's safe to say that the power to charge the coil is coming from the alternator and not the cap.
