Well done on the wristpin extraction.
Unfortunately, they look unuseable.
Nice flash of inspiration with the toolkit assemblage. The other 2 screws would need a hammer-type impact driver for removal. Sometimes they'll loosen if you hold pressure and torque on the screwdriver while hammering it like a chizel.
The condition of the crank is of utmost importance.
Rocking the rods side-to-side, should get less than 2mm movement as measured at the small ends.
The wristpin holes should be checked for excessive clearance. Using the best, clean, undamaged end of one of the wristpins as a gauge, slide it into a rod end. Should be a light drag slide-in fit, with no noticable looseness...
