Spent a blissful afternoon working on the bike and got a lot done- was a warm 60 degree day. The motor is almost ready to turn upside down for the case split.
Removed the pressure and clutch plates and push rod, and was stunned to see two balls tumble out- I don't think this is correct. The clutch diagram in the xs1b service manual shows only one 5/16" ball. (#16)
Anyone have a clutch holding tool by any chance?
Also removed what I could of the alternator- waiting for the rotor puller, put my name in the floating tool section.
Took off the drive sprocket- going to replace it.
Also spent some time on the frame, removed both wheels, and swing arm- ready for detabbing and sandblasting:
Some questions regarding the swingarm- I assume there is nothing to remove from inside the swingarm holes in the frame? Just clean out the grease in prepping for sandblasting/powdercoating?
Also when removing the swingarm, one of the bushing slid out easily but the other one is pretty stuck- how do you remove the distance collar and swing bushing?
View attachment 62972 View attachment 62973
