Another at Barber.
You can go ahead and buy that one for me… thanksView attachment 252825
Another at Barber.
If you mean the difference between the XS650 and the XS500, I have both and seat-of-the-pants tells me they would be close with equal riders. The 650 has better low-end torque, but the 500 likes to rev and is smoother at higher rpm. Just an old slow guy's opinion.I wonder how the performance compares to the 650. The power numbers differ 5 hp, but from what I have read, a stock 650 has maybe 45 rwhp, so the difference may even be less than 5 hp. And the 500 is a bit lighter as well.
Doesnt the acetone trash all of the seals? even the ones which are still ok? Diesel is far more easy to deal with. If it doesnt free up after a week in diesel , arule of thumb is that it needs help. Hitting it with anything is a last resort. Strip the motor down as far as possible. all you know now is that it siezed. gearbox ? piston? big end?primary drive?If something in the gearbox failed and jammed in the works..... a chain tensioner dropped into the crank case and jammed the crank? .The kindest thing is to drop the oil. search the oil with a magnet. remove the engine and start to strip it. the further you go , the more you'll know.I have read that a 50/50 mix of ATF and acetone is very effective.
I think I would be inclined to go to Option 2. The 1974 engine could show up with a crack in the cylinder head. Then, you’re right back where you started.Dilemma…..with options … this is back to the 1973 Yamaha tx500 build
Option 1- can purchase a 74 engine with good compression- engine is $400 plus shipping $265 - total $665
Option 2- purchase missing parts - engine top end - $200 plus gaskets and bolts $100- total $300
Option 3- choose option 1 or 2
There are no bikes to be found other than too far away.
Thoughts??
I'd find out if the crank's any good before making a decision. Would suck to just buy the top end and then find out you also need the bottom.Dilemma…..with options … this is back to the 1973 Yamaha tx500 build
Thoughts??
I guess I will go ahead and remove the engine and start taking it apart. I’m pretty curious why it’s binding. I hope I can get parts for it.
Thanks. Have a whole box I still need to go through. Main thing is the engine is free and fingers crossed, compression is healthy. Guy I bought all this from was just overwhelmed with multiple projects and knew he would never get around to this one.he kinda threw in the bike as a part of the dealNice parts grab! Those exhaust look nice and frame looks fairly clean.
I wish but….. I’m being optimistic. I’m obviously not going to take the bike on a cross country trip or anything . I’m restoring a bit of history, especially the aesthetics aspect.Is that the newer head, the one that doesn't crack, lol ?
