Hey guys, found a new xs650 to start up, everything works so far, except this leak from the carbs that's only happening where the fuel gets fed into the carbs. that "t shape" piece that lets fuel into both carb bowls. I'm new to the special. it's the red one on the cover of the manual, that's the special G right? I didn't get much info with the bike. But yeah, that piece between the carbs moves side to side a little bit, and leaks only from there. I couldn't find specs or a chart or even much in the manual about it. is it maybe a bad gasket seal inside?
