76 upper brake line bracket, attach to what?
Norton7d
XS650 Junkie
Sacramento
I will eventually be going with another brake line, but what does this attach to?
It's item 20 in the diagram.
Well the attachment bracket portion of it has a built in nut thus I assume it attaches to something which hangs down, no hard frame threaded hole needed.
Norton7d do you have your Standard handlebars back on that 76 ?
Head light ears and rubber mounts in good shape?
Looking forward to seeing all that ..
:cool:
:cool:
Working on this now, bucket off and waxed, al wires exposed, hoping to suceed at putting humpty dumpty back together.
Great ! I’ve found it easiest to first set the steering bearings close to tight.
Forks then set aligned and at height (without messing with the ears yet) by pinching the lower 4bolts.
Then again removing the top triple clamp/handlebars to install the headlight ears and rubber mounts. With correct heights set the rubber mounts very lightly greased, will be snug vertically. Not too loose or too tight.
Top triple clamp/bars back to snug after
Steering stem bearing check.
Lft and Rt control wires, gauges, clutch cable routed lastly along with the ears/signals into the bucket.
It took me a couple tries to get it done easily and well.
Good going :cool:
:cool:
Yes. Bars back on, headlight and mounts have some patina, running that way, if I make her to pretty, I'll never ride her.
Already done more than i thought i would, i will finish the day it starts raining!
Sure hear that and feel the same up here. Well, winter months are easily the most productive in the garage
Looking forward to seeing your Blue 76 standing proudly
-R
Just getting more parts actually on the bike instead of in boxes all around the bike
G'day Mate from Oz,
By the colour of your headlight shell you have a '76C.
Just love the name of your machine.............I decided to call my'76 "Puff The Tragic Wagon" due to the fact I cannot find a frustrating engine oil leak.
When I take him on a club run and we park up some stupid bugger says "your engine is leaking oil", my reply.........No he is just marking his teritority
