Picked up a seat off FB on the cheap and even though it’s for a 78SE other than the normal issue with the slack in the latch it’s much better than the fart catcher I had on there.
Also received the fuel filters I was waiting on so I hooked up the gas line, poured some fuel into the tank and figured I’d see how it runs. First mistake, trusting the old petcocks. Just touched them and gas poured out every orifice the had. OK I have the set I bought that had one weeper that I worked on and figured it couldn’t hurt. Also I’m lucky I had two sets of new screws because the existing ones looked like someone had tried to take them out with a #1 Phillips. The fix I wrote about in the petcock thread must have worked because everything seems fine. Whoop, no, there’s gas pouring out of right carb. Tapped the bowl and that fixed that. Used the kicker to start it and yessir! Runs a little rough due to not having the Airboxes on but runs. Took a spin down the street and she shifts and is really very smooth. Pulled up to the garage and she idles. I looked down and now the left carb has a stuck float needle. Tapping didn’t take care of it so I will have to pull them back off so I can use a q-tip on a drill with a little toothpaste or something to clean those seats better.
