ChromeFox
XS650 New Member
Hi everyone:
I'm Brendon, and I'm an '82 Suzuki GS650 owner. My best friend, who, for some bizarre reason, hasn't created a user name on this forum yet, is the owner of a 1982 Yammie XS650. It's an inline twin.
He's been experiencing running problems with this bike....which was sold to him last month as "not running, but some TLC ought to straighten out the problems.
Further inspection leads me to think that, based on my GS experience, this bike had dirty, or mis-synced carbs, valve adjustment problems, or both.
I've determined that the bike has Mikuni BS-CV carburetors. However, (because I have a plethora of BS-32mm. carb parts) it seems unlikely that my buddy's twin has the same Cv carbs as my in-line 4. I'm going to guess that the internal diameter for the XS is either 34mm or 36mm (or, perhaps, larger).
First question...does anyone out there in XS land know the inside throat diameter of the coveted Mikuni for an '82 XS650 twin?
Once I know what the size Mikuni parts I am searching for (and, if any of you Yamaha wizards know what carb parts might be compatible between a CV32mm to the larger sizes
) I can begin showing him what he can buy.
Second question...Does the XS experience the same kind of intake boot o-ring problems the Suzuki GS does? Briefly, once the intake boot o-ring becomes old and brittle, it cracks, allowing unregulated air into the cylinders. Is this an issue I ought to look for on my friend's bike? It's common on the 80's model Suzuki GSes. If we run Mikuni BS-CV carbs, it seems like this might be a shared issue.
Third question...If you're not hip to www.cycleorings.com, you should be. This guy's got the hookup on Mikuni o-rings that might save you a bundle on rebuild kits. Just supply your own fuel bowl gaskets (and float needle seats....if you gouge the hell out of them removing them like I do....) My question here is....where do the Yamaha wizards find parts? www.z1enterprises.com has a substantial selection for vintage Japanese bikes, but the insiders always know the best deals. I'm sure this '82 likely has never seen a valve adjustment. Where do I find shims? Does anyone have any suggestions above the valve adjustment procedure?
Thanks for your time and attention guy. If it makes you feel any better, I'm not a complete newb. I owned an '80 XS 850 triple. I adored that bike. It got repossessed in the foreclosure of my buddy's house. I always imagined what might have been......but the Suzuki brand came along, and I couldn't stop myself from a good deal. I guess this is fate's way of bringing me back to Yamaha.
Thanks once again.
-Brendon
) I can begin showing him what he can buy.Second question...Does the XS experience the same kind of intake boot o-ring problems the Suzuki GS does? Briefly, once the intake boot o-ring becomes old and brittle, it cracks, allowing unregulated air into the cylinders. Is this an issue I ought to look for on my friend's bike? It's common on the 80's model Suzuki GSes. If we run Mikuni BS-CV carbs, it seems like this might be a shared issue.
Thanks once again.
-Brendon
