There is no number on the frame, i know that an owner 3 PO's ago built it as a custom so that will be where the frame conversion comes from and numbers filed off and powder coated over. The engine number 3L1 022032 puts the engine as a XS-SF. It has been registered against the engine number, the frame is in very good condition no rust anywhere but i did have to cut the rear swingarm bolt and sleeve out. Everything else looks standard 1980ish stuff. I had another good look at the discs and i might just squeeze and skim out of them but if i can get alternatives that is good.
Hi nb1914,
I reckoned 1980 because that's the only year I know of that had a disk rear brake.
(edit) Finally remembering that my friend's '79 has a disk rear and then checking Skull's photo array to see that '78SEs, '79SFs, '80SGs & '81SHs all had 'em.
And yes, as posted, your engine's ID sez it came out of an SF.
But as XS650 parts swap from year to year just like LEGO, who knows what year the frame was? (end edit)
Filing the frame number off seems a bit dodgy to me but as the 4th owner since then
the cops can't very well pin it on you, eh?
But unless your disks are in far worse shape that the photos indicate, I still recommend
doing a drill job on them.
I drilled mine with 3/8" holes and a decade later their surfaces have actually improved.
If I'd to do it over I'd have drilled more holes but used a 5/16" drill bit instead.
