Hi,
I have an XS650 custom street scrambler which was built up with an Sr500 rear drum brake, presumably because the builder couldn't obtain an XS drum brake. The problem with this setup is that, even with an 18T front sprocket, the bike is under-geared. I've made a 38t rear sprocket, which is the smallest size I can go to due to the config of the SR500 hub, but it's still under geared.
Over here in the UK there isn't a xs650 hub or wheel to be had, so I need to find a plug and play alternative. I believe the TX750 will fit but again, none available in the UK. I can get a MX250 wheel, but with no drum plate. Will the mx250 fit? Is the axle size the same as my SR500 setup? And are there other hubs that will do? Ideally I need a hub with a mount bolt PCs significantly less than 164mm, which is what my SR500 is. Machining a new 33t sprocket from a platewheel.is no problem, so it's just knowing what options are available. Any help here guys?
