TurboFarviknugn
Am i correct in thinking, that when the trans is in gear and the clutch lever is pulled in that the bike should move freely ?
Cause mine DONT !
I have screwed the lever adjuster all the way in removed the sidecase adjuster cover loosened the lock nut turned adjuster screw clockwise until tension is felt (expirimented and screwed it past that point) tightened locknut, but still the same result, can feel engine turning with lever pulled in. Whats wierd is it feels like there is clutch there, but just wont wont roll without turning engine over.
Ant thoughts ? did i miss a step ? Btw followed haynes manual.
Cause mine DONT !
