I did exactly the same thing. +1 on the torch to heat up around the area. Use a vice/lock grip to turn the stud out. Heat up the metal and touch a candle to the hot surface, the wax will melt and act as lubrication on the threads. I am actually not sure how useful this candle wax trick is. I saw it done on Youtube and it also worked for me on this exact same stud, so give it a try if needed...? I also picked up a replacement stud from the local hardware store instead of Mikes.
