TC2000
Hi knowledgeable XS fans,
I am servicing my xs1. Removed the plate below the engine where the oil filter is. Found a loose hard rubber plate. It comes from the cam chain tensioner: just below the pinion that is pressed against the chain. I cannot figure how it was attached to the aluminium block which is part of the tensioner: flat hard rubber surface against flat aluminium surface!?! No screw, no trace of glue... The tensioner is the early type with 4 screws.
Do you think that rubber plate is useful ? can I omit it?
I see only very slight chain rubbing marks on the aluminium piece...
Any idea ? Thanks for your help,
TC2000
TC2000
