Sure seems there could be wiring connection issues still. My bike was popping and would quit, then would fire up again. Even though it visually looked fine, it was the spade connector block to reg/rec. Had to totally replace it as the internals of the plastic block connectors were worn and not properly seating the spade connections together. These old bikes really require that you remove, clean, and reinstall each terminal in the block. It's a time consuming mission, but helps to eliminate wiring connections as a variable when diagnosing charging issues.
