pumps
XS650 Junkie
Today I bit the bullet and pulled off the right side cover and got my clutch apart. I've read a lot of posts about it and still have questions. From the condition of the heads of the spring screws I's say someone has been in the before. My Clymer manual shows 6 friction plates and 5 steel plates. One parts fiche diagram for the D, E, and F models shows 7 friction and 6 steel which is what is in the bike actually. Mikes shows the 6/5 being oem so I guess it's been changed on the bike. My friction plates are too thin according the the micrometer so I'm getting new ones.
I know about the 2-2-2 on the washers but am a little unclear as to order. Again the crankcase there is a smaller diameter washer then a larger one, correct?
Then between the driven gear and the needle thrust washer there should be one? Then another. Same size?
Under the nut should be a spring washer(as called on mikes site) to the outside and a washer closer in ?
My clutch springs are in spec so I think I will reuse them. Any tips? Gonna take my spring screws up to my pal Kent in KCs house and do the allen head mod.
