Tristan530
I have really become disheartened and regret buying the 1970 XS650 I did on Ebay. What was supposed to have been a restored bike was done with what seems to be little care, or more specifically done but no time taken to see if adjustments needed to be made or things redone. From what I can tell from the guy I bought the bike from, he started it only a few times and took it for one short "test ride." I should have known the trouble I was getting into when the bike arrived and I noticed leaking fork seal and small pools of oil on the engine case. Things have just got more complicated and the guy I bought the bike from won't even bother to reply to my emails now ask for advice.
Latest issue is oil leaking from the bottom of the clutch case. I got the cover off (which was a task in itself) and see that a liquid seal was used in addition to a usual "paper" gasket. My question is does the fact that both a paper gasket and liquid gasket was used tell me there was a leak that the seller knew about that would not be prevent by a paper gasket alone?
The guy I bought the bike from seemed real upfront and a general good guy. Seems that he didn't give me the full story on the "restoration." And other than an initial apology for the significant leaks on the cylinder head and seam, has given no indication of taking more responsibility for the problems (that I am not all skilled to handle myself and must go pay a shop to do).
I suppose that if I look at the bright side, this latest problem will give me an opportunity to polish the case before putting it back on.
Should I just go ahead and put on a new paper gasket together with a liquid gasket? Appreciate any advice.
