fullercameron
Had the bike up and running for about 600 miles and the other day it died at a stop light. My starter doesn't work so the bike is kick only right now and I could not get it to start. It didn't even sound like it was trying so I pulled the voltmeter out of my bag to see what was in the battery.
I had 9 volts in the battery. I was lucky and near an auto supply store and they hooked the battery up on their charger for five minutes or so and I got the bike to fire and got it home.
I looked through some of the threads on testing the charging system and did a couple of the tests. when I place a wrench near the alternator cover (within a 1/2") and turn the key, it doesn't move. The battery is fully charged now - AGM battery that was reading just over 13V. If it fails this test, does this automatically indicate that my rotor is toast?
Second, I started the bike up and tried to see what kind of voltage I was getting at the battery if I revved the engine to 3000+ rpm. The voltage was dancing all over the place and I couldn't seem to get a steady reading (it is a digital meter). It was fluctuating from what looked like 18V to -? to 13V and I could not get a fix on what the hell it was putting out at full speed. Does this little voltage dance indicate that some other component has failed or does it just demonstrate that I don't know how to perform this test properly?
I see where the thread talks about how to bypass the regulator to test its function, but can I just test the voltage at the battery to see if I am charging?
I'd like to eventually do a PMA swap, but I can't really afford to do it now and would like to keep the bike on the road for at least the next month or so without having to charge the battery every night.
Also, when I charge the battery, it reads full and shuts off, but if I disconnect it and reconnect it to the charger, it seems like it will read less than full and begin charging again. The battery is only 3-4 months old. Is there a quick way to load test a battery just to double check that this isn't also an issue?
Thanks. I know that this is a lot of questions wrapped up into a big ball of I don't have a clue right now, but any assistance would be greatly appreciated. I certainly wouldn't have gotten this far without your help.
