darynar1016
So this is my first build and this site has been really quite helpful for random bits of information I may need. This is one I can't quite find an answer for so here is what I'm working with:
I am running 34mm XS650 front end, I have no idea what year it is. It has some weird damper assembly that I haven't seen in any of the manuals.
I want to run a dt100 mini drum front wheel with a Avon speedmaster.
My axle width for the front end is 17mm and the DT100 is 12mm.
I am considering having spacers made for my forks to run the 12mm axle with the 17mm fork spacing but wondered:
Will the axle be too thin for running on this chopper? Does anyone have experience running this front wheel/anything like it?
And if the spacer idea won't work, has anyone ran anything like this a different way?
I have read that some people have drilled out the drum a few mm and used the stock axle with new bearings in the hub. That seems permanent and risky compared to just using metal spacers.
Just looking for any input.
I was also curious as to what ratio speedometer I can run with the dt100 wheel? Didn't know if anyone had any experience or ideas with this too?
And do the DT100's have front brake stays? I can't seem to see where it would go/mount and I wanted to find out before I have my forks shaved.
I know that was a lot of rambling but I wanted to make sure I got everything out.
Thanks and I appreciate and help anyone can offer.
