Oldtramp53
My stepson had the heads rebuilt and has not been able to get the old xs to fire since seems like it should be a timing issue to me.Any ideas this is my first go on these xs's
Thanks for the info I'll be looking into that right awayYou should probably back up one more step and assure the motor was assembled correctly, that the cam was timed to the crank right. Here's an easy method without having to tear it down again .....
http://www.650motorcycles.com/CamTiming2.html
Then you can go about verifying the external timing settings. On the advance rod that runs through the cam, there are locating pins on each end for the points cam and the little disc that ties into the advance unit. These should be aligned, pointing in the same direction. It's possible to install them with the pins set 180° to one another, and that's what throws the timing off 180°......
Thanks grzld1,I haven't taken a look at this myself yet,I'll be checking elec power spark etc.as soon as I get out there and charge batt.I just wanted to get a starting point ,s .Still like 16 degrees out there no heat I garage .Oh, for cryin' out loud! Didn't anybody think to ask if the plugs spark at all? If the spark is weak to nonexistent, condenser ground is one of the first things to check; a favorite amateur hour trick is to paint over the contact point on the frame. Also, have you inspected the point gaps and timing? Refer to the factory service manual for specs and procedures--it's a free download at http://www.biker.net.
Are you getting power to the ignition coils? Check with a volt meter. If it shows voltage at the coils 1/2 volt or more lower than voltage at the battery, you have some work to do on connectors, switches, and/or wiring.
This business of checking if the advance rod is in phase can be done with a fast and direct inspection. Just pull the left cylinder exhaust valve cover and observe which points open when the valve is closed (tappet loose). There is no voodoo involved here; the breaker point ignition should spark leading into the power stroke, not the exhaust stroke, and that occurs when the points open.
