CoastsideXS650
Princeton Motor Works
I just purchased a 1980 xs650 Special II and I am having issues with a high idle speed.
you can see the thread here:
http://www.xs650.com/forum/showthread.php?t=40368&highlight=lucille
When riding, as I pull in the clutch, the idle shoots up to about 3-4000 rpm. When I kill it at high idle and start the motor again, it is at normal idle (1500ish rpm).
Motor:
stock TCI ignition
rebuilt from the head up. did not break piston seal.
valves and camchain properly adjusted.
carbs:
completely rebuilt with new butterfly seals and proper float height.
Stock jetting
uni pods
New JBM carb boots
I also have a chopper that was running fine with no such idle problems. So I took the carbs from the chopper and put them in this bike. Now it has much better idle. but after warming up a little down the street, the same issue kept popping up. Maybe it is a little less severe but its still there. The chopper carbs have a bigger pilot and main jet. It is tuned with uni pods and open exhaust with no muffler.
I sprayed carb cleaner all over the butterflies, boots, and intake. Nothing changed.
Anyone have any idea what could be going on here?
Motor:
stock TCI ignition
carbs:
Stock jetting
uni pods
New JBM carb boots
