MFJustin
Welcome to Thunderdome
Hey guys, back again with another question.
After piecing my new project together over the past few months I'm finally on the home stretch. Got the bike running the other night after buying it as a non runner and its only a few things away from being completely road worthy. Just need to tune my carbs properly and address this issue that I'm having with my transmission.
I followed the detailed write up on here for adjusting your clutch. Before I couldn't shift through any gears at all and after a bit of playing with the adjustment on the left side cover worm gear and the adjuster on the handlebar I've got a decent albeit stiff clutch pull and I am somewhat able to cycle through the gears. Here is the issue....
I cannot get the bike to shift through all of the gears like it normally would at a standstill. With the clutch pulled in, I can downshift it into first, instead of being able to immediately click it up into second gear and beyond I have to rotate the front sprocket a bit before it will click into the next gear. I confirmed this at first by hand rotating the sprocket through all the gears and then once I put the chain on the same thing happens. I've only done short little rides up and down my street to tune various things and it does ok while the bike is in motion. If I'm stopped with the bike on sometimes I can't click it down into first gear unless I walk the bike forward a bit while sitting on it and then it pops in. Like I said it seems to shift seamlessly through the gears as long as the bike (and therefore the sprocket) are in motion, but the moment the bike is stopped I cant just pull the clutch in and click through all the gears and back down, I have to walk the bike forward a bit until what seems like the sprocket rotates enough to click it into the next gear.
Just wanted to see if anybody had any tips, I bought this bike as a non runner because the owner abandoned a project halfway through due to a baby but he said it ran great before he took it apart and based on what I've encountered taking it apart so far I do believe him on that. I dont know if this is still a clutch misadjustment issue or something else. The ball bearing is still inside of the worm gear from what I can see, and its an 81 so it has the long clutch pushrod. Thanks in advance guys. Cant wait to get this hang up fixed so I can get it on the road.
