The Tin Man
I am having problems putting my rear brake Rod and lever together. I thought it might be because of the longer Radeon swing arm and I also thought I may have had the wrong brake actuator lever the one that came with the box of bits is the one on the left in the picture with the bent arm so I ordered a xs 650 from a supplier it is straighter but I still have the same problem it seems that the locator for the brake wear switch interferes with the travel of the brake rod I'm wondering if I can remove the tab without any problems it might solve the issue. Im also wondering which of the two break actuator evers i should I be using. lastly the pin that connects the rod to the brake actuator I have two of these one is threaded one is not I also have an adjuster nut on the end which is threaded on the rod I don't see how I can adjust the PIN or the pivot if it's threaded I thought it should slide on the rod please clarify thanks in advance Tin Man
