Hugh's HandBuilt - Weld On Headlight Mount
Punkskalar
Hugh's HandBuilt
Asheville, NC
Q: "How did you mount your headlight on that bike"
A: "This Simple Weld-On Mount Right Here"
Folks, this is one of those amazingly simple products, that will make your bike look like a pure custom – and for a fraction of the time/cost to make it yourself. We used to make these by hand for all of our builds – and have been complimented many times over how clean the mount looks compared to bolt-on options out there. We've even been asked "Who makes that lower tree?"before – It's that clean of a look for your front end folks.
And now it's available to you. The Hugh's HandBuilt Weld-On Headlight Mount.
Pre-Drilled 12mm Holes fit MOST Aftermarket Bottom Mount Headlights, or if needed you can drill it out.
2 Different Mounting Holes, allow for a custom fit – Tuck in the headlight or bring it out a bit – it's up to you
Hefty Laser 1018 Laser Cut Steel – Those XS650 vibes won't be breaking this bad boy
Easy to Mount (Grind, Weld, Done)
Laser Cut from 1018 Steel
Custom Fabricated Look
Clean Install – No Bolts
Guaranteed not to Break – No more broken mounts from Vibration
In stock at www.hughshandbuilt.com
Thanks so much for your support folks!
Hugh
