smiles79
So I have a 1975 XS650 with a pair of Mikuni round slide carbs. It was at the point where it would idle but die as soon as I give it gas (unless the choke was on). When this happens I can hear a noise come from the carbs. I now have it to where it will maybe cough a little with the choke off then rev up properly, but then sometimes it will stick at a high idle, usually around 3000 rpm (from what I've gathered, this means it's probably running lean?). I tried adjusting the air screw (mixture screw?) And with the brake side all the way in, the bike was running the same same as it was with the screw 1.5 turns out.
As of right now the air screws are 1.5 turns out and the idle adjustment screws are 4 turns out. Also, I can see a flame come out of the exhaust pipe when the engine has almost completely stopped after shutting it off, which would lead me to believe it's running rich (contradictory to what I was thinking above). Any ideas as to how to fix this?
Thank you all in advance, I hope you can help me.
