bennecc
Before I forget, this applies to an '81 Special II with Pamco.
My bike hasn't been charging; after poking around w/ the multimeter I came to the conclusion that the brushes just need replacing (fingers crossed). I ordered a set but they won't be here for a few days.
In the mean time I decided to try to do some mild carb tuning. I started with a freshly charged new-ish battery. Today I started up the bike on full choke no problem. I was messing with the idle and waiting for it to heat up when it died. It probably ran for 1-2 minutes. Then I couldn't get it to start. A couple hours later it started up and did the same thing. When I try to start it after it doesn't sound like it is close to starting. It does kind of sound like a hiss as I kick it over (I'm not sure how do describe that sound, its nothing drastic, just something I noticed). Occasionally it will nearly catch, other times a loud "crack" and a bit of smoke out of the air filters (I think that's where the smoke comes from). I pulled a plug (new) and grounded it to the head and kicked it over.....definitely more of an orange spark than a blue one. Plugs were a bit black and wettish so I cleaned them off. I checked voltage on the battery and it was around 12; that seems like plenty to get a good spark, right?
Anyways, I ran out of time and left it after that. Anyone have any ideas what I should be checking? Could all this be related to the bike not charging? (I put the battery back on to recharge)
Also, I had adjusted the valves a few days ago and found all 4 of the nuts either backed waaay off the tappet or completely off and rattling around. Today I checked again and one of the nuts was backed way off again! It was the first valve I adjusted a few days ago so I think I must have not tightened it very hard as I hadn't yet realized all of the nuts were so loose. Anyways, I retightened it and I'll keep an eye on it. Anyone have that happen to them?
